Archicad C++ API
How to create assosiative dimensions
arad
How can I create dimensions that interlock with walls, columns, etc.?
I looked at the following page, but the information seems to be outdated.
The structure and members seem to be different.
https://archicadapi.graphisoft.com/documentation/frequently-asked-questions?s=dimension#FAQ_3
https://community.graphisoft.com/t5/Developer-forum/Dimensions/m-p/84474
Do you have a sample code?
Akos Somorjai
Hello Arad,
Oh, maybe you have an older version of the DevKit. Let me enclose that part of the code.
Best, Akos
5 REPLIES 5
Akos Somorjai
Please take a look at the Do_CreateAssociativeDimensions() example code in Element_Basics.cpp.
Best, Akos
Hello, Akos.
Thank you very much.
However, I cannot find Do_CreateAssociativeDimensions.
Do_CreateStaticDimension is there.
Am I looking at something wrong?
Akos Somorjai
Hello Arad,
Best, Akos
Hello Akos.
Thanks for your help.
I will try it.
We are creating an associated dimension for the column and beam. Is it possible?
For me, neig.inIndex changes for line, wall and object, but column, beam.. does not change.
i cat create associated dimension for line. but don't ... for column
Why doesn't inIndex change? - Graphisoft Community
AC27 on window 11
