I've tried using the APIEnv_GetNumberingGridLinesID. It gives the grids coordinates and based on these lines I can get the following:
- Number of Cells
- Distance from Margin
- Grid line type (and color)
How/where can I get the "Start from" and "Primary Direction"? (When I got the grid lines, I assumed that the start and end points of each lines will tell me the "Start from", but they don't.)
- OR BETTER -
How/where can I get the complete information about this settings?
EDIT 1:
I found out that the grid values are the one shown on the layout. That is, if a grid was split into two by a drawing, this will now become two grid values.
~ReignBough~
ARCHICAD 24 INT 4018 FULL (from AC18)
Windows 10 Pro, Intel Core i7-4790 CPU @ 3.60GHz, 32.0GB RAM, 64-bit OS
