GDL
How to set Real values in the parameter section GDL
Partha02
Whenever I am using GDL and there need to set a Real value instead of an Integer, it always rounds up the number and sets the value as Integer. How can I set a Real type and also get the Real (not the rounded up) value in the parameter section?  gdl round.pnggdl round 2.png
Thank you.
For a height, I would be using a 'length' type parameter.
Then the decimal precision is set in your 'Working Units' in Project Preferences.
If you really want to use a 'Real Number' then the decimal precision will also be in the Working Units for 'Numbers without Units'.
Barry
Barry
vdentello
Even though it shows rounded, it keeps the decimals "hidden" AFAIK.
You may also want to set a fixed value though parameter tab.
Archicad User Since 2013
GDL Developer
Experimenting with API
from Brazil
