Developer forum
Hyperlink for ArchiCAD objects?
I can't find a hyperlink property for ArchiCAD objects (other CAD applications like AutoCAD, Revit, Triforma, etc. have them). Does such a thing exist in ArchiCAD?
thanks in advance, Chuck
20 REPLIES 20
No. There is no hyperlinking tech in GDL objects other than the special hyperlink in the Comment script that is accessed from the object settings dialog only. No hyperlinking from any model views.
I believe Kimon Onuma or someone else was implementing an add-on to create hyperlinking effects.
One of the forum moderators   •   AC 25 USA and earlier   •   MacOS 11.6.7, iMac Pro
Thanks for the quick reply. I've contacted ONUMA, Inc. about the hyperlink add-on. If I don't get a reply, I'll probably implement it myself unless anyone has any better ideas.
thanks, Chuck
Thanks to Akos for pointing out:
ACAPI_Database(APIDb_GetElementURLRefID, &elemHead, &elemURLRef);
ACAPI_Database(APIDb_SetElementURLRefID, &elemHead, &elemURLRef);
One solution leads to another question though:
In looking at the menu-related API, it doesn't look like you can modify the right-click context menu, right? It would be nice to add "Follow Hyperlink..." to this menu for an element that has a hyperlink...
Does the situation with hyperlinking remains the same for the time being?
Holger Kreienbrink
You can place one Hyperlink in the comment script.
#http://.......
Then the button with te earth changes from the default webpage to the user defined page. But you can just create one link
Holger Kreienbrink
Leitung Produktmanagement D/A/CH
Munich, Germany
Sorry, Holder, I cannot find place in AC12 where this comment script is situated . Could you point out the menu entry?
rocorona
It is the Comment Script of the GDL objects. You can access it when editing Library parts.
_________________
--Roberto Corona--
www.archiradar.com
AC18 - ITA full on Win10
_________________
_________________
Ok, I select some object, open it in the library object editor, click on the Comment button and fill the right text area with some URL.
But I cannot see anywhere the Earth icon to follow this URL! Please, help!
Vladimir:
In the Object dialog box, the Comment option of the Preview must be selected for the Comment and www link to appear (most users never select this option).
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
AC24 USA • iMac 27" 4.0GHz Quad-core i7 | 24 gb ram • MacBook Pro 2.8GHz | 16 gb ram • OSX10.15.7
Hi Vladimir
When you open the object in the editor you must put the # in front of the URL in the comment script eg #http://.....
Otherwise this will put a URL button in the interface script:
UI_BUTTON UI_LINK, "Visit Website", 200,180, 100,20, 0,
"http://www.graphisoft.com"
I'm quite certain the right-click web link WAS there a couple of versions
ago...possibly AC10 or AC9. Now obsolete for some odd reason.
It should come back soonest and be scriptable and not static.
Thanks GS, looking forward to it!
Checked and it is ArchiCAD 9 that has the right-click www-link for objects.
Yes i agree, they should definitely bring this feature back!
In the Interface Script you can use hyperlink too.
UI_BUTTON UI_LINK, "Visit the website", 291,135, 100,20, 0,"http://www.masterscript.nl"
gdford
Has this feature been disabled in Ver 14? I can place the URL in the comment section proceeded with the # character and it displays correct next to the earth symbol....but nothing happens when I click it.
Gary Ford
Self Employed - Modeling, Estimating, Construction
Archicad 12-25
AMD Ryzen 9 5900X 12-Core Processor
3701 Mhz, 12 Core(s), 24 Logical Processor(s)
(RAM) 128 GB
NVIDIA RTX A2000
Looks like it.
I just tried and nothing happens.
Versions 6.5 to 25
Dell Precision 3510 - i7 6820HQ @ 2.70GHz, 16GB RAM, AMD FirePro W5130M, Windows 10
I have no problem to access the site the url is pointing to, but I have AC12. But, my problem is: When I press Preview from the Interface Script or I press the button when I'm using the GDL, I go to the site,
but AC12 crashes every time I click in AC.
This is a serious problem, naturally. Do someone have an idea?
hmmm that sounds odd. is your AC12 up to date?
Probably not! I never install updates 🙂
But I "solved" the problem by just putting the link in as a text.
So then "people" can copy the address.
