Archicad C++ API
I can't sign in at https://archicadapi.Graphisoft.com.
LeeJaeYoung
AC27 on window 11
Turned out to be a local issue at LeeJaeYoung. In case you experience anything similar, please contact your local support for further assistance.
Noémi Balogh
Community Expert, Admin
16 REPLIES 16
Graphisoft is having a server problem related to GSID sign-in.
it seems to be working now?
One of the forum moderators
it doesn't work yet.
AC27 on window 11
Works fine for me.  I signed out and then back in just now.
Can't connect to sign in.
AC27 on window 11
Have you tried a different browser?  I.e., if the error is from Microsoft Edge, have you tried Chrome?
Has anything about your firewall, etc, changed?  Do you have a VPN, so that you can temporarily appear to not be connecting from Korea in case there is some strange IP thing going on?
Chrome has the same problem.
You blocked Korea.
I can only access with vpn.
Why do they do this?
AC27 on window 11
Thanks for reporting that you can log in using a VPN.  I'm sure there is nothing intentional directed at Korea... and have asked Graphisoft to follow up on this problem you are having.
Noemi Balogh
Hi @LeeJaeYoung,
As Karl said, we have no intention to exclude South Korea from our API site. Your issue seems to be individual at the moment, so may I ask you to get in touch with our Developer Support team: https://graphisoft.atlassian.net/servicedesk/customer/portals
They will be able to help you fix this.
Thank you,
Noémi
Noémi Balogh
1. It is possible to connect with vpn.
2. Here it is said that the password is wrong.
https://Graphisoft.atlassian.net/servicedesk/customer/portals
AC27 on window 11
