GDL
I want to turn off the orange vertical dashed lines that appear in the wallhole section view.
LeeJaeYoung
Studying GDL
After solving the problem below, another problem arose.
I want to turn off the orange dashed vertical lines in the section view. What should I do?
Image is cross sectional and punched through a wallhole.
However, a broken vertical line appeared on the left.
I want to turn this line off.
Where should I set it up?
I think it has something to do with the wall opening.....
AC27 on window 11
LeeJaeYoung
MVO에서 door off
AC27 on window 11
1 REPLY 1
LeeJaeYoung
MVO에서 door off
AC27 on window 11
