GDL
INFIELD{2} not displaying VALUES{2} properly
Bruce
I have defined a 2-dimension array parameter, of integer type, with a VALUES{2} command. It displays fine in the parameter list, but in the interface, I only get the integer displayed, not the description. What am I missing?
I think I've encountered this before, but I can't remember what I did to solve it (apart from placing a dummy OUTFIELD over the top of the infields...a bad solution).
Parameter array values:
Interface result:
Bruce Walker
www.brucepwalker.com
Barking Dog BIM YouTube
Mindmeister Mindmap
-- since v8.1 --
AC27 5003 INT Full | Windows 11 64 Pro | 12th Gen Intel i7-12700H 2.30 GHz | 64 Gb RAM | NVIDIA GeForce RTX 3060 32 Gb
Palawat
Let's say that your parameter is paramName, try this ;
! Master Script
dim paramNameSt[]
paramNameSt[1] = "Room Name"
paramNameSt[2] = "Room Number"
paramNameSt[3] = "Room Category"
paramNameSt[4] = "Room Category Code"
paramNameSt[5] = "Room Abbreviation"
paramNameSt[6] = "Room Area"
dim paramNameInt[]
paramNameInt[1] = 1
paramNameInt[2] = 2
paramNameInt[3] = 3
paramNameInt[4] = 4
paramNameInt[5] = 5
paramNameInt[6] = 6
values{2} "paramName", paramNameInt, paramNameSt
! UI Script
ui_infield{3}	paramName[1][1], 10, 10, 200, 20,
				8, "",
				vardim1(paramNameInt),
				1, 0, 0, 0, 0,
				paramNameInt, paramNameSt, paramNameInt
Archicad 26, Windows 10, Corei7 3.4 GHz, 16 GB Ram.
https://www.indigofigs.com
https://www.facebook.com/indigofigs
Palawat
! Master Script
dim paramNameSt[]
dim paramNameInt[]
paramNameInt[1] = 1
paramNameInt[2] = 2
paramNameInt[3] = 3
paramNameInt[4] = 4
paramNameInt[5] = 5
paramNameInt[6] = 6
! UI Script
				8, "",
				1, 0, 0, 0, 0,
Bruce
That did the trick! Thanks Palawat.
Bruce Walker
Mindmeister Mindmap
-- since v8.1 --
