GDL
Is there a name that can be obtained from GDL, such as MVO NAME or GOC NAME of VIEW?
LeeJaeYoung
Is there a name that can be obtained from GDL, such as VIEW's LAYER COMBINATION LAYER, MVO NAME, or GOC NAME?
AC27 on window 11
runxel
Legend
GDL has no access to these values, sorry.
Lucas Becker | AC 27 on Mac | Author of Runxel's Archicad Wiki | Editor at SelfGDL | Developer of the GDL plugin for Sublime Text |
«Furthermore, I consider that Carth... yearly releases must be destroyed»
4 REPLIES 4
runxel
Legend
Wasn't it necessary for you who are old users?
i need it....
I'm trying to have a view name as well, but it can only be used in the title.
AC27 on window 11
No, not really.
I wished once for this feature, but I'd still rather describe that as a hack.
If we had this possibility this would create potential mayhem and would lead to non-deterministic behaviour.
In nearly all instances there are other ways to solve the thing you need.
thank you so much
AC27 on window 11
