GDL
Label for opening codes in GDL
David Shorter
How do I create a label to show these codes. (the 4 codes inRED)
Archicad 4.1 to 27 Apple Silicon
you can't build a line
Mac Studio
iPad Pro
iPhone
The Right and Left is simply the orientation.
But I don't think doors have any concept of what is inside or outside - at least as far as autotext goes.
The schedules have a 'view from reveal side' and 'view from opening side', but I don't see any autotext values for opening side.
There is a parameter for 'ac_wido_reveal_side_2'
0 = opens to same side as reveal side.
1 = opens to side opposite reveal side.
So if your reveal is always on the outside and your door has that parameter, you should be able to use this in a scripted label by using ...
rrr=REQUEST ("ASSOCLP_PARVALUE", "ac_wido_reveal_side_2", name_or_index, type, flags, dim1, dim2, p_values)
if p_values is 1 then it opens inside otherwise it is outside.
Mind you I have not tried to create a label that does this so just a theory on my part at the moment.
I had a quick play.
I couldn't get the 'ac_wido_reveal_side_2' parameter to work.
But I used the global 'WIDO_REVEAL_SIDE' and then set a parameter to say 'Inside' or 'Outside'
if WIDO_REVEAL_SIDE = 0 then
	window_open_side = "Outside"
else
	window_open_side = "Inside"
endif
PARAMETERS window_open_side = window_open_side
Then I used that in the label ... rrr=REQUEST ("ASSOCLP_PARVALUE", "window_open_side", name_or_index, type, flags, dim1, dim2, p_values)
Seems to work OK.
Add in the orientation (left, right) and you should be good to go.
Peter Baksa
Use the globals described here at flipping. WALL_FLIPPED is also needed if you want to match it to the wall's inside/outside.
Péter Baksa
Software Engineer, Library as a Platform
Graphisoft SE, Budapest
