GDL
Leaf thickness for door marker
neilmcallister
I'm trying to make a custom door marker. One piece of information I want to use is the door leaf thickness. I have been trying to wade through the door script to find out what the parameter might be called with no success. I am looking for the parameter with the tooltip "Leaf Thickness" in this screenshot from the standard UK library - but I expect it is the same everywhere. Does anyone know the name of this parameter or where I should be looking to find it?
Archicad 26 / Windows 11
gs_leaf_thk is the one you are after.
Creator of Cadswift's parametric GDL libraries
Creator of Infinite Openings and Component Catalogues
Push the envelope & watch it bend
website: https://cadswift.com.au/
YouTube: https://www.youtube.com/user/CADSwift/playlists
4 REPLIES 4
neilmcallister
Excellent. Thank you. That does exactly what I need. I had tried searching for "thickness" and "thick" but hadn't thought to try "thk".
Peter Baksa
In the GDL editor Parameters window the search box searches in parameter names and descriptions too.
Péter Baksa
Software Engineer, Library as a Platform
Graphisoft SE, Budapest
neilmcallister
Thanks. I've found that now - which would have been a much easier way to find it in the first place. Definitely quite a learning curve, but also the possibilities are endless.
