2021-07-12
11:44 PM
2021-09-14
12:00 AM
Noemi Balogh
DIM myArray[][] myArray[1][1] = 500 myArray[1][2] = 510 myArray[2][1] = 600 myArray[2][2] = 610 myArray[2][3] = 620 myArray[3][1] = 700 myArray[3][2] = 710 myArray[3][3] = 720 myArray[3][4] = 730VARDIM1(myArray[1])
2021-07-12 11:48 PM
2021-07-12 11:52 PM
2021-07-13 12:04 AM
2021-07-13 12:07 AM
dushyant wrote:What do you call sub-array? Could you refer to GDL manual page about (and provide AC version)? Because one of us does not understand it correct.
Because I need the size of the sub-array myArray[1] (that is the value 2 in my example) and not the entire parent array myArray
2021-07-13 12:15 AM
Podolsky wrote:Yes, but I don't need that.
So, VARDIM1(myArray) will give you 4 and VARDIM2(myArray) will give you 3.
2021-07-13 12:25 AM
2021-07-13 12:28 AM
2021-07-13 12:29 AM
Derived Types
Variables and parameters can also be arrays, and parameters can be value lists of a simple type.
Arrays are one- or two-dimensional tables of numeric and/or string values, which can be accessed directly by indexes.
2021-07-13 12:31 AM
