‎2021-02-06 01:00 AM - last edited on ‎2021-09-14 09:57 AM by Noemi Balogh
‎2021-02-06 02:30 AM
‎2021-02-06 07:54 PM
‎2021-02-07 03:51 AM
runxel wrote:Possibly, you may have that reversed. JSON is used to wrap the Python commands in a database format (json) so that any language that supports json can send commands (inquiries) to Archicad.
Even the official Python API is more or less an example, since that "API" is barely anything more than a wrapper around the JSON API.
‎2021-02-07 01:42 PM
poco2013 wrote:No, Gerry. Seems more like you got that reversed somehow.
‎2021-02-07 06:14 PM
‎2021-02-07 08:48 PM
poco2013 wrote:I don't want to argue with you, but I still have to point out, that there seems to be a misunderstanding here.
I have written several Python interfaces/applications with Archicad and never used JSON and don't intend too. Python can be used by itself, either internally or externally, and I have demoed both without JSON The classes and commands are completely Python and run in the Python embedded environment.They simply request data from Archicad. JSON is a Data format not a Programming language.
‎2021-02-08 11:11 AM
