2022-08-02 04:52 PM - edited 2022-08-02 07:00 PM
Hi All
OK have cmake running and have my VS and Xcode projects appearing. ✅
Now I am having issues with building an example project on the Mac.
PC also had this issue but installing Python fixed it..
On the M1 mac
Python is installed with version 3 and 2.7
Side issue:-------
I tried checking if my Archicad 26 Python palette was working.
But I got this message
"Python Palette is only available with SSA subscription."
I have a developer license and can't access Python ?!!🤷🏼
I have updated the project Architecture to "x86_64" to no avail
Anyway, I can't get any example project to build and it looks like Python is the problem..
If anyone could help, it would be greatly appreciated.. TIA
Solved! Go to Solution.
2022-08-04 08:44 AM
Hi Ben,
I'm able to compile Add-Ons on an M1 Mac for AC26, but I had a similar issue. My fix was to change the relevant line in CMakeLists.txt from "python" to "python3" (it's line 149 in the example add-ons). Alternatively you could make the command "python" available by other means e.g. a symlink. Let me know in case that you need more information. You can always check in your terminal if the commands "python" or "python3" are available.
As for the AC26 python palette. I also have a developer license and I'm able to use the python palette also in AC26. I recently renewed my developer license and it took a few weeks after that for GS to upgrade it to AC26. Does the license manager say, that you have a AC26 license?
Best, Bernd
2022-08-03 06:16 PM
OK.. I have now tried on my old Intel mac with the same error..
Has ANYONE had success compiling a version 26 example project on Mac?
2022-08-04 08:44 AM
Hi Ben,
Best, Bernd
2022-08-04 05:56 PM
Thanks Bernd
I should have worked that out!!..
I had to modify one of my scripts like this a few months ago..
I am now able to compile ... 👍
The entire Mac development process is obscure to say the least.
Cmake adjustments
Architectures set to x86_64 from arm64
Then there is the notarization process for addons
And none of this documented AFAIK...
I thought the 'Blog' on Archicad API would help but it hasn't been touched for years....
Anyway, lucky there are people like you around Bernd 👍 (and Gerry and others)
