2020-12-14
07:45 PM
2021-09-15
09:26 AM
Noemi Balogh
Solved! Go to Solution.
2020-12-15 02:25 AM
Win10 | R5 2600 | 16GB | GTX1660 |
2020-12-15 05:43 PM
Lingwisyer wrote:Sounds too onerous.
You would have to edit the objects script and isolate that variable.
2020-12-16 02:13 AM
2021-01-08 10:49 PM
Lingwisyer wrote:Hi Ling - I am now trying to edit the GS object, but it won't let me do anything at all in the 2D View window. The NCS Drawing Title 2 24.gsm is read only.
I can be...
From memory, the GS symbols are not that hard to navigate. Also, given that it is a title, there is no need to worry about incorporation and rotation or mirror script sections.
Ling.
2021-01-09 02:59 PM
Rene wrote:You should Save As... the library part, so your edits are in a new file, not altering the existing file. (The file is Read Only because it s part of the .lcf file)
Rene wrote:The 2D View only shows the result of the code. Changes need to be made to the 2D Script to change the library part.
Rene wrote:In the main library part window, click the Parameters button to see the parameters. Go to AC_DrawingRect in the Variables column near the bottom of the list, click the little grid under in Values column (this is an array that stores multiple values), and change the 5th value to zero. The Parameters window holds the default values for the library part. Since the title has not been placed on a Layout in the environment, it does not contain this information (it is pulled via a Request command). It is best to place your marker on a Layout to test the results of your code changes as you work on the code.
Also, when I open the 2D View, it appears at an angle and there is no layout number on it. (see attached screenshots). Any advice?
