GDL
Moving multiplied element with hotspots
ArchiMind
Hello everyone,
Being that I am still new at ways of GDL, I could use assistance.
I am trying to create simple cells that can be moved with hotspots. I understand the basic concept of how to make them move, but the question is how to make them move when they are multiplied. To be precise how to move them individually with different values.
For now, I made  Value 1 and 2 move, but the Value 3 is for me brain teaser.
In the following the  code:
hsid=1
RECT2 A,0, 0,B
RECT2 A-margin,margin, margin,B-margin
!Title cell
Fill hatch1
POLY2_b 5,7,hatch_pen1,hatch_pen_background1,
margin,B-margin,1,
A-margin,B-margin,1,
A-margin,B-margin-title,1,
margin,B-margin,1
Y1=B-margin-title
!Subtitle INSTALATION block
POLY2_b 5,7,hatch_pen2,hatch_pen_background2,
margin,Y1,1,
A-margin,Y1,1,
A-margin,Y1-subtitle,1,
margin,Y1,1
!=============== INSTALATION NETO VALUE ===============!
Y2=Y1-subtitle
Y3=Y2-YC
FOR n=1 TO 3 STEP 1
!Total VALUE cell
Fill hatch3
POLY2_b 5,7,hatch_pen3,hatch_pen_background3,
margin,Y3,1,
A-margin,Y3,1,
A-margin,Y3-value,1,
margin,Y3-value,1,
margin,Y3,1
ADD2 0, -value-YC1
NEXT n
DEL 3
!HOTSPOT VALUE CELL
!========== VALUE 1 =========!
HOTSPOT2 margin,		Y2, 	hsid+1, YC, 1+128:	hsid=hsid+1		!base (hidden)
HOTSPOT2 margin,		1, 		hsid+1, YC, 3:		hsid=hsid+1		!referece
HOTSPOT2 margin,		Y3, 	hsid+1, YC, 2:		hsid=hsid+1		!moving
!========== VALUE 2 =========!
HOTSPOT2 margin,		Y3-value,		hsid+1, YC1, 1+128:	hsid=hsid+1			!base (hidden)
HOTSPOT2 margin,		1, 				hsid+1, YC1, 3:		hsid=hsid+1			!referece
HOTSPOT2 margin,		Y3-value-YC1,	hsid+1, YC1, 2:		hsid=hsid+1			!moving
!========== VALUE 3 =========!
HOTSPOT2 margin,		Y3-value-YC1-value, 			hsid+1, YC2, 1+128:hsid=hsid+1		!base (hidden)
HOTSPOT2 margin,		1, 								hsid+1, YC2, 3:	hsid=hsid+1			!referece
HOTSPOT2 margin,		Y3-value-YC1-value-YC2, 		hsid+1, YC2, 2:	hsid=hsid+1			!moving
Parameters:
Also, I would like to know is it possible to embeed schedule information in GDL object, in that sence that we can create  graphical more appealing area schedule?
Stefan Veselinović
Versions 13 to 25
CPU: AMD Ryzen 9 5900X 12-Core
RAM:32GB
GPU: RTX 2080Ti
Windows 11
Peter Baksa
You can use ADD2 between different hotspots to make their base and value clearer. The reference hotspot should be in the other direction from base than moving.
GDL objects don't know about other GDL objects, scheduling is not possible.
Péter Baksa
Software Engineer, Library as a Platform
Graphisoft SE, Budapest
6 REPLIES 6
The hotspots are fairly simple, but as far as I know the only way to get any schedule data into a gdl object will be with python.  You can't even use properties in gdl yet.
Peter Baksa
Péter Baksa
ArchiMind
Thank you Peter for the explanation.
In the meantime, I restructured the code so I could learn to use subroutines
I managed to accomplish most of the things that imagined, but I have difficulty to figure how to move a certain hotspot, so it deducts from the B value.
Picture of explanation what I am struggling with
Object code:
hsid=1
RECT2 A,0, 0,B
HOTLINE2 0,0, 0,B
HOTLINE2 0,B, A,B
HOTLINE2 A,B, A,0
HOTLINE2 A,0, 0,0
HOTLINE2 margin,margin, margin,B-margin
HOTLINE2 margin,B-margin, A-margin,B-margin
HOTLINE2 A-margin,B-margin, A-margin,margin
HOTLINE2 A-margin,margin, margin,margin
HOTSPOT2 0,0
!========== GS A direction RIGHT CORNER =========!
HOTSPOT2 0,		0, 		hsid+1, A, 1+128:	hsid=hsid+1		!base (hidden)
HOTSPOT2 0,		-1, 	hsid+1, A, 3:		hsid=hsid+1		!referece
HOTSPOT2 A,		0, 		hsid+1, A, 2:		hsid=hsid+1		!moving
!========== GS B direction RIGHT CORNER =========!
HOTSPOT2 A,		0, 		hsid+1, B, 1+128:	hsid=hsid+1		!base (hidden)
HOTSPOT2 0,		0, 		hsid+1, B, 3:		hsid=hsid+1		!referece
HOTSPOT2 A,		B, 		hsid+1, B, 2:		hsid=hsid+1		!moving
!========== GS B direction LEFT CORNER =========!
HOTSPOT2 0,		0, 		hsid+1, B, 1+128:	hsid=hsid+1		!base (hidden)
HOTSPOT2 0,		B, 		hsid+1, B, 2:		hsid=hsid+1		!moving
!=============== TITLE CELL ==============================!
Fill hatch1
margin,B-margin,1,
margin,B-margin,1
!=============== BLOCK 1 ==============================!
!HOTSPOT2 margin,margin+value+tvalue
ADD2 0,B-margin-title-subtitle
GOSUB "SUBTITLE"
DEL 1
ADD2 0,B-margin-title-subtitle-CELLheight
GOSUB "PARAMETARS"
DEL 1
ADD2 0, B-margin-title-subtitle-CELLheight-block1-value
GOSUB "VALUE"
DEL 1
ADD2 0,B-margin-title-subtitle-CELLheight-block1-value-subtitle
GOSUB "SUBTITLE"
DEL 1
ADD2 0,B-margin-title-subtitle-CELLheight-block1-value-subtitle-CELLheight
GOSUB "PARAMETARS"
DEL 1
!========== BLOCK 1 GS UPPER PART =========!
HOTSPOT2 margin,		0, 					hsid+1, block1, 1+128:	hsid=hsid+1		!base (hidden)
HOTSPOT2 margin,		1, 					hsid+1, block1, 3:		hsid=hsid+1		!referece
HOTSPOT2 margin,		-block1, 			hsid+1, block1, 2:		hsid=hsid+1		!moving
DEL 1
Y1=value+subtitle+CELLheight
!========== BLOCK 1 GS LOVWER PART =========!
HOTSPOT2 margin,		-Y1, 				hsid+1, block1, 1+128:	hsid=hsid+1		!base (hidden)
HOTSPOT2 margin,		-Y1-block1, 		hsid+1, block1, 2:		hsid=hsid+1		!moving
DEL 1
!=============== BLOCK 2 ==============================!
ADD2 0, B-margin-title-subtitle-CELLheight-block2-value
GOSUB "VALUE"
DEL 1
ADD2 0,	B-margin-title-subtitle-CELLheight-block2-value-subtitle
GOSUB "SUBTITLE"
DEL 1
ADD2 0,	B-margin-title-subtitle-CELLheight-block2-value-subtitle-CELLheight
GOSUB "PARAMETARS"
DEL 1
!========== BLOCK 2 GS UPPER PART =========!
HOTSPOT2 margin,		0, 			hsid+1,		block2, 1+128:	hsid=hsid+1		!base (hidden)
HOTSPOT2 margin,		1, 			hsid+1, 	block2, 3:		hsid=hsid+1		!referece
HOTSPOT2 margin,		-block2, 	hsid+1, 	block2, 2:		hsid=hsid+1		!moving
DEL 1
!========== BLOCK 2 GS LOWER PART =========!
HOTSPOT2 margin,		-Y1, 		hsid+1,		block2, 1+128:	hsid=hsid+1		!base (hidden)
HOTSPOT2 margin,		-Y1-block2, hsid+1, 	block2, 2:		hsid=hsid+1		!moving
DEL 1
!=============== BLOCK 3 ==============================!
ADD2 0, margin+tvalue
GOSUB "VALUE"
DEL 1
ADD2 0,margin
GOSUB "TVALUE"
DEL 1
END
!========= SUBROUTINES ============
"SUBTITLE":
Fill hatch2
margin,subtitle,1,
A-margin,subtitle,1,
A-margin,0,1,
margin,0,1,
margin,subtitle,1
RETURN
"VALUE":
Fill hatch3
margin,value,1,
A-margin,value,1,
A-margin,0,1,
margin,0,1,
margin,value,1
HOTLINE2 margin,value, A-margin,value
HOTLINE2 margin,0, A-margin,0
RETURN
"TVALUE":
Fill hatch4
POLY2_b 5,7,hatch_pen4,hatch_pen_background4,
margin,0,1,
margin,tvalue,1,
A-margin,tvalue,1,
A-margin,0,1,
margin,0,1
RETURN
"PARAMETARS":
ADD2 margin,0
RECT2 0,0, CELLroom,CELLheight
HOTLINE2 0,0, CELLroom,0
ADD2 CELLroom, 0
RECT2 0,0, 	CELLwall,CELLheight
HOTLINE2 0,0, CELLwall,0
DEL 1
ADD2 CELLroom+CELLwall, 0
RECT2 0,0, 	CELLfloor,CELLheight
HOTLINE2 0,0, CELLfloor,0
DEL 1
ADD2 CELLroom+CELLwall+CELLfloor, 0
RECT2 0,0, 	CELLceling,CELLheight
HOTLINE2 0,0, CELLceling,0
DEL 1
ADD2 CELLroom+CELLwall+CELLfloor+CELLceling, 0
RECT2 0,0, 	CELLperimeter,CELLheight
HOTLINE2 0,0, CELLperimeter,0
DEL 1
ADD2 CELLroom+CELLwall+CELLfloor+CELLceling+CELLperimeter, 0
RECT2 0,0, 	CELLarea,CELLheight
HOTLINE2 0,0, CELLarea,0
DEL 1
DEL 1
RETURN
I would appreciate the help.
Cheers
Versions 13 to 25
RAM:32GB
GPU: RTX 2080Ti
Windows 11
Peter Baksa
It looks like it should change the overall length of the box too?
Then you have to synchronize B with the edited length in the parameter script using GLOB_MODPAR_NAME. When the user edits one of them, the other has to be re-calculated.
Péter Baksa
Thank you for the replay.
Yes overall length of the box would change.
Regarding your answer I must admit it is a bit abstract for me in the sense that I don't really know how to implement it technically at this point, being that I started on my GDL journey two weeks ago and that I don't have prior coding experience.
Could you give some concrete code structure that I could try, so that I could learn from the example?
Thank you for your patience.
Cheers
Versions 13 to 25
RAM:32GB
GPU: RTX 2080Ti
Windows 11
With GDL users can change only one parameter at a time (except transferring settings and setting array parameters, but that is a more advanced topic), after each change the scripts will be executed. When any parameter's change (either from UI or hotspot) should affect other parameters' values, these changes have to be calculated in the parameter script. Your script can decide what calculations need to be done based on GLOB_MODPAR_NAME global variable, which is filled with the last changed parameter's name (case-sensitive).
The linked article has an example under "Displaying custom parameters in tracker".
Péter Baksa
