I am looking for an example of creating and applying the NCS Indicator label, The element test example only demos the basic text label and following that pattern gives the error RefusedCMD. I can find the library part NCS Indicator but after that nothing works. It seems like some special handling is required for these label symbols?
Anyone familiar with this label and how to configure??
EDIT: Sorry -- Found the problem -- I had a double undoable command which i overlooked
However, if anyone has a example i would appreciate the help . For example is the NCS part a Text label or a Symbol? What would be the variation ID? IOW -- What are the general parameters needed in order to create this part without relying on the default settings. I do not want to have to set or rely on a default before creating the label
Gerry
Windows 10 - Visual Studio 2019; ArchiCAD 26
