Archicad C++ API
Need precision on C4D light properties
drjustice
The light properties as given by the ModelerAPI are a bit too rudimentary for me. For this reason I am enumerating C4D light properties by calling ModelerAPI::Light::GetExtraParameters()
I found some documentation on C4D light properties here:
http://gdl.graphisoft.com/tips-and-tricks/how-to-make-a-light-object
However, I would need clarification on a couple of things.
- Photometry units can be lumen or candela. I assume you mean "Candela per Square Meter" ?
- What is c4dDetAreaX, c4dDetAreaY? I assume it's the area beyond which falloff starts to occur (eg: 100% light intensity within the area/volume, and starts to falloff beyond the area/volume)?
- The documentation doesn't mention a c4dDetAreaZ for an omni light, but when I enumerate the properties I see a C4D_DET_AREAZ. I assume this is just a bug of the documentation?
- What does c4dDetRadius mean? Is it the distance from which light goes from 100% to 0% but beyond the c4dDetAreaN? If so, then, along an axis, the light coverage and intensity curve would be something like this?
total length of light coverage = c4dDetRadius + c4dDetAreaX + c4dDetRadius
shape of light curve = ...oooOOO + ######### + OOOooo...
- What is the unit of c4dDetRadius and Areas? I assume meters?
- Can you describe the falloff behavior for an omni light with falloff geometry types of OMNI, SPOT, AREA, CONE, PYRAMID and how it relates to c4dDetFalloffAngle?
- Why have to specify the light intensity in both Lumen and Candela? Why not specify a single unit and value, and let archicad convert between the two?
- Can you confirm meaning for c4dPhoPhotometric? 1=photometric, or 0=non-photometric? How do you get intensity & unit of non-photometric lights?
- What is c4dVisBrightness? Is it a percentage multiplier to the light intensity, like a dimmer switch?
Thank you!
0 REPLIES 0
