Archicad C++ API
Newbie questions
Hi there!
First of all I've got a problem starting the development since I dont really know how to get started.
I mean, Iv'e got much experience with programming, but no clue when it comes to using programming for archicad.
Where do I start? I mean, how do I use my code in archicad?
furthermore, how can I get an access to the project properties, for example how can I actually get the actual number of floors in my project? etc...
thanks!
6 REPLIES 6
First page to visit:
http://www.graphisoft.com/support/developer/
Download the API kit from here:
http://www.graphisoft.com/support/developer/downloads/index.html
Get the documentation from here:
http://www.graphisoft.com/support/developer/documentation/index.html
Ralph Wessel
Mentor
BBman wrote:
Hi there!
You'll need either XCode for the Mac OS or Visual Studio 2005 for Windows, and should be reasonably proficient in C (ideally C++).
Laszlo has given you all the relevant links to the API and documentation. It's mostly a matter of reading the documentation and looking through the examples. Your add-on code is ultimately built into a DLL that is loaded by ArchiCAD as required.
Information about storys (floors) is retrieved by calling the function ACAPI_Environment with the identifier APIEnv_GetStorySettingsID.
Ralph Wessel BArch
Thx.
Well, Iv'e got the visual studio 2010, will it do the work?
Ralph Wessel
Mentor
Possibly, but I don't recommend trying. You will save yourself a lot of trouble if you stick to the specified development environment.
Ralph Wessel BArch
stefan
Where is the API documentation? It is not visible on that page. Only library, LP_XMLConvertor and ODBC driver
Archicad27/Revit2023/Rhino8/Unity/Solibri/Zoom
MBP2023:14"M2MAX/Sonoma+Win11
Archicad-user since 1998
my Archicad Book
Ralph Wessel
Mentor
That page is a bit misleading. The documentation for the API is bundled with the API developer kit at: http://www.graphisoft.com/support/developer/downloads/
Ralph Wessel BArch
