Developer forum
Object placement in plan view
MetalFingerz
I am making a landscape object that would usually be placed on a mesh. A mesh doesn't necessarily have all its points at the same Z level so I would like to know if, while in plan view, it's possible to force an object to be placed at the proper Z value?
In 3D, it works as the origin point gets to the accurate Absolute Base Height but when in plan view, the object is placed at the story level (which is normal behavior obviously). Is it possible to make it so that when I click on the mesh where I want the objet to be, the object could somehow "read" the mesh height and place itself there ?
I don’t have ArchiCAD in front of me at the moment so this is from memory.
When you place any elements there is a gravity tool you can activate.
I am sure it has a mesh option.
Versions 6.5 to 25
4 REPLIES 4
Versions 6.5 to 25
Barry wrote:
When you place any elements there is a gravity tool you can activate. I am sure it has a mesh option.
Barry is correct. It can be accessed via the Coordinates palette.
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
AC24 USA • iMac 27" 4.0GHz Quad-core i7 | 24 gb ram • MacBook Pro 2.8GHz | 16 gb ram • OSX10.14.6
MetalFingerz
It was that simple
Thank you both for those quick replies
But, be aware that Gravity works only during placement. If you later modify your Mesh so its top surface changes, those Objects placed using Gravity will not follow the changes in the top surface. No such associativity is created between the Object and the Mesh.
In such a case, you may have to place those Objects again with Gravity to ensure proper vertical position.
Laszlo Nagy, Lead Moderator, Community Admin
Get Archicad Tips at https://twitter.com/laszlonagy
AMD Ryzen 1700X CPU, 48 GB RAM, Nvidia GTX 1060 6GB, 500 GB NVMe SSD
2x28" (2560x1440), WIN10 PRO ENG, AC20-AC25
Loving Archicad since 1995
