Developer forum
Only seeing 2 items at my Addon menu
I have a problem with the menu buttons to use my API scripts. I have more then 2 menu items (5).
When I’m adding my add on through Add-on manager everything is ok but after I close Archicad and opening it again (my addon is already loaded), I only see the first 2 menu items.
The solution is to again - unload and reload the addon but this means I have to do this for every time I open Archicad.
It’s important to say that the addon works fine - shortcuts for menu items that I am not seeing..
Thanks in advance!
1 REPLY 1
Hello
Anyone has an idea?
