Developer forum
Opening symbol 21 Object
rav668
I am looking for source code of object named in the topic. Is there any way to obtain sourcecodes of objects made by GS? I would like to make some improvments on my company's own use.
Thanks in advance,
Rav
4 REPLIES 4
runxel
Ace
Just open it?
Select it in the view, press CMD+shift+O
Mostly AC 26 on Mac | Author of SelfGDL | Developer of the GDL plugin for Sublime Text |
«Furthermore, I consider that Carth... yearly releases must be destroyed»
rav668
runxel wrote:
Just open it?
Problem is that the scripts are empty, so I am looking for help here.
Erwin Edel
It calls the object from the Master script.
EPS = 0.0001
if GLOB_SCRIPT_TYPE <> 7 & GLOB_SCRIPT_TYPE <> 8 then
	call "slabOpeningSymbol_m" parameters all iSymbolType		= 1
endif
Just open the slabOpeningSymbol_m object by highlighting the name and using CTRL+SHIFT+O or CMD+SHIFT+O.
www.leloup.nl
ArchiCAD 9-26NED FULL
Windows 10 Pro
Adobe Design Premium CS5
rav668
EPS = 0.0001
endif
Thank you very much that is what I've been looking for
