Archicad C++ API
Outdated AddOn
Dayiz
Dear Community,
I managed to build my first AddOn and it works perfectly on my machine, but when i try it on another i always get the error "Diese Datei ist ein veraltetes Add-On, dass mit dieser Archicad Version nicht verwendet werden kann." (Deepl Translation: "This file is an obsolete add-on that cannot be used with this Archicad version.").
So I found
https://community.Graphisoft.com/t5/Developer-forum/Using-the-Development-Kit-with-Visual-Studio-202...
where a similiar problem is explained. I installed the previous MSVC v142 as explained in the post and added the parameter to my CMake Project
But even after just building the Example AddOn i got the same error on other machines.
I tried it through command prompt instead of using the CMake GUI
But I'm still getting the error on other machines.
I also found something similiar in the FAQ:
https://archicadapi.Graphisoft.com/faq
The 2nd point of "My add-on runs perfectly on my development machine, but when I install it on the client’s machine it refuses to load." it says:
[...] The required runtime version can be correctly set in the add-on’s manifest file.
Where or what is that manifest file? I can't find any further explanation on it.
What am I missing?
Dayiz
Well, i found my problem. It was actually the first point of https://archicadapi.Graphisoft.com/faq , I always published a debug version and not a release version. So i changed the settings in VS to Build and it works!
But I'm still curious about the manifest file, still havn't found it
julienK
Yes, otherwise it wouldn't work on my EDU version (addons without mdid should only work with demo versions of Archicad)
Dayiz
