2020-11-14
03:50 AM
2021-09-15
12:31 AM
Noemi Balogh
2020-12-11 08:13 AM
2020-12-11 11:30 AM
2020-12-11 03:50 PM
2020-12-12 04:07 AM
2020-12-12 10:37 AM
2021-01-19 02:08 PM
leceta wrote:
Archicad also has been developed "for decades", sure.
The difference is that McNeel has been developing mainly the "geometry engine" while Archicad's is a BIM tool (documentation, collaboration, issue management, IFC support... In comparison, Rhino's support for all these functionalities is (almost) inexistent.
But geometry in Archicad is mainly based on primitive solids and discretized curves. And this is ok IMO. Good enough for 99% of the architectural projects. Digital Project from Ghery technologies was developed to support the geometry limitations of BIM tools like ArchiCAD.
Rhno and Archicad. Two apps, two purposes.
By the way, Archicad is already 'very' parametric software, isn't it? Certainly, not the same explicit parametric modelling paradigm as in Digital Projects, for example, but still parametric. Maybe you are looking for a different app?
2021-01-19 10:48 PM
2021-02-20 06:52 PM
furtonb wrote:
When can we expect the macOS release?
2021-02-21 11:02 PM
2021-03-25 03:20 AM
2021-04-14 08:44 AM
Jim wrote:Hi Jim,
I am a Mac user and have been waiting for this ever since it was announced.
I have already built a few components in a matter of a day.
However there are a few features I think would make life a little easier.
1. Display of variable/number values
Sometimes, when components are not behaving as expected, it would be nice to see exactly what values are being passed
2. Display of axes and origin
It is easy to lose track of exactly where these things are, having a visual display would be much easier
3. Logical operators
It would be nice to have conditional statements to use with the parameters, so that based on some values, we could set others. This is useful for validating user input. I'm building a spur shelving component and it would be good to set a minimum value for the height of the shelves. There is a balance to be struck between the overall height and spacing of the shelves, so there is a conflict between shelf numbers, spacing and height. The only way I can find of resolving this is to use logical statements to filter the inputs.
4. More options for list input of values
I don't know how to configure user input so that it is limited to a list of variables. When we are designing components for others to use, it can be easier if some components have plain text options for input which translate to numeric equivalents. For example if I want to configure washtrough heights, it's easier if we allow users to choose the age group, and have the parameters filled in automatically. Otherwise they will have to look up what the recommendations are. Currently I can't find any way of doing this. Also - some numeric series do not necessarily have consistent intervals. I don't know how we can deal with this either.
5. Option to increase number of decimal places displayed.
Units are metres, so parts parameters often need to work to 4 decimal places. Having Param-o round these up in the display is really unhelpful.
6. Indicator to show which variables are user-configurable parameters
When you have lots of variables, it can be nice to be able to see at a glance which ones are user-configurable. This could be a different colour/shade dialog or even a graphical indicator.
7. Facility to add notes/comments to nodes
Node trees can get very complex very quickly, and it can be tricky to keep track of what you are doing at what stage. The ability to show or hide explanatory comments would help in development a lot I think.
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
2021-04-17 04:21 PM
2021-04-19 09:42 AM
scraptrash wrote:Please keep this topic 100% focused on PARAM-O. Any new topics should be... you guessed it... started in a NEW topic/thread.
I’ve a general question about GDL I have in mind for some time.
Why there is no 2-way interactive graphical object modeling interface for GDL?
By interactive interface, instead having to input the coordinates either in GDL or param-o viewport, graphical viewport can also let me draw a cube as easy as in archicad project and the GDL code is immediately generated interactively. Then I can manipulate the codes and the graphical viewport changes accordingly.
