2020-07-23
03:51 PM
2022-09-26
01:48 PM
Daniel Kassai
PROJECT2{4} 3, ! projection_code = 3 (top view), 270, ! angle = 270 1, ! useTransparency = off, 1+2, ! statusParts = 1 + 2 (all parts) 1, ! number of cutplanes (can be 0 but 1 or more preferred) 18", ! cutplane height ! UNSCLICED OBJECTS ONLY (VIEWED FROM TOP) 3, ! method (0 = hidden, 1 = wireframe, 2= hidden lines, 3 = shading) 1+2+4+8+16+32, ! parts to generate 2, ! cut fill index 1, ! cut fill pen -1, ! cut fill background pen 0.0, ! cut fill origin x, 0.0, ! cut fill origin y 0.0, ! cut fill direction angle 1, ! cut line pen 1, ! cut line type 2, ! projected fill index 247, ! projected fill pen 121, ! projected fill background pen 0.0, ! projected fill originsx, 0.0, ! projected fill origin y 0.0, ! projected fill direction 248, ! projected line pen 1, ! projected line type ! SLICED OBJECT 2 + 16 + 32 + 128 + 4096,! method (1 = wireframe, 2= hidden lines, 3 = shading) 1+2+4+8+16+32, ! parts to generate 2, ! cut fill index 245, ! cut fill pen 245, ! cut fill background pen 0.0, ! cut fill origin x, 0.0, ! cut fill origin y 0.0, ! cut fill direction angle 245, ! cut line pen 1, ! cut line type 1, ! projected fill index 248, ! projected fill pen 121, ! projected fill background pen 0.0, ! projected fill originsx, 0.0, ! projected fill origin y 0.0, ! projected fill direction 253, ! projected line pen 1 ! projected line type
2020-07-23 06:51 PM
2020-07-24 05:43 AM
2020-07-27 03:06 AM
rotz 45 rotx 45 roty 45 block 1,1,1 del 3With 0 cutplanes the cutplane height mustn't be given, we are viewing the whole model from infinity:
project2{4} 3, 270, ! projection_code, angle, 0, 1 + 2, ! useTransparency, statusParts, 0, ! numCutplanes, ! 1, ! cutplaneHeight1, 3 + 32, 4 + 8, ! method1, parts1, 0, ! cutFillIndex1, 0, 0, ! cutFillFgPen1, cutFillBgPen1, 0, 0, ! cutFillOrigoX1, cutFillOrigoY1, 0, ! cutFillDirection1, 0, 0, ! cutLinePen1, cutLineType1, coverfill, ! projectedFillIndex1, viewpen, 0, ! projectedFillFgPen1, projectedFillBgPen1, 0, 0, ! projectedFillOrigoX1, projectedFillOrigoY1, 0, ! projectedFillDirection1, viewpen, solidline ! projectedLinePen1, projectedLineType1The parameters commented cut... are irrelevant here.
project2{4} 3, 270, ! projection_code, angle, 1, 1 + 2, ! useTransparency, statusParts, 1, ! numCutplanes, 1, ! cutplaneHeight1, ! slice cutplane to bottom: shading with attribute override, cut and view 3 + 32, 1 + 2 + 4 + 8, ! method1, parts1, cutfill, ! cutFillIndex1, cutpen, 0, ! cutFillFgPen1, cutFillBgPen1, 0, 0, 0, ! cutFillOrigoX1, cutFillOrigoY1, cutFillDirection1, cutpen, solidline, ! cutLinePen1, cutLineType1, coverfill, ! projectedFillIndex1, viewpen, 0, ! projectedFillFgPen1, projectedFillBgPen1, 0, 0, ! projectedFillOrigoX1, projectedFillOrigoY1, 0, ! projectedFillDirection1, viewpen, solidline, ! projectedLinePen1, projectedLineType1 ! slice top to cutplane: wireframe with attribute override, view 1 + 32, 8, ! method(numCutplanes+1)), parts(numCutplanes+1), 0, ! cutFillIndex(numCutplanes+1), 0, 0, ! cutFillFgPen(numCutplanes+1), cutFillBgPen(numCutplanes+1), 0, 0, ! cutFillOrigoX(numCutplanes+1), cutFillOrigoY(numCutplanes+1), 0, ! cutFillDirection(numCutplanes+1), 0, 0, ! cutLinePen(numCutplanes+1), cutLineType(numCutplanes+1), 0, ! projectedFillIndex(numCutplanes+1), 0, 0, ! projectedFillFgPen(numCutplanes+1), projectedFillBgPen(numCutplanes+1), 0, 0, ! projectedFillOrigoX(numCutplanes+1), projectedFillOrigoY(numCutplanes+1), 0, ! projectedFillDirection(numCutplanes+1), overheadpen, dashedline ! projectedLinePen(numCutplanes+1), projectedLineType(numCutplanes+1)
2020-07-27 05:34 PM
