GDL
Poly2 flips the line
runxel
Legend
When using a symbol line for poly2 and its brethren it will flip the line direction at the rounded parts. With the native polyline this of course does not happen.
What did I miss?
Lucas Becker | AC 27 on Mac | Author of Runxel's Archicad Wiki | Editor at SelfGDL | Developer of the GDL plugin for Sublime Text |
«Furthermore, I consider that Carth... yearly releases must be destroyed»
Podolsky
Ace
Try to change direction how to describe nodes (clockwise or anticlockwise). That might help.
Podolsky
Ace
runxel
Legend
You were right.
I had the the coordinates "PUT" in the wrong order. After I have reversed it to be CCW everything looks fine again.
Somehow the obvious things are always to be overlooked at first glance
Thanks!
