GDL
Prevent (!) Line elimination
runxel
Legend
Hey folks, I have a TUBE{2} and need my lines to be NOT eliminated.
See this picture below, just two cubes (as dummy) to show the issue. If you stack them, they will join and I somehow need to prevent this from happening, since they need to be visually different.
The MASK parameter for the tube{2} is set to 1+2+16+32, which means, the line elimination flags are not set (especially looking at you, 1024!).
Yet, it still eliminates the line between the two objects.
runxel
Legend
Oh I have to apologize by the way:
The example above is not TUBE{2} but a simple PRISM_. (I changed it later, that's why.)
Sorry!
So with Prisms it always eliminates lines, even without a BODY -1 being in place!
With TUBE{2} it works as advertised. It will eliminate lines if the mask flag has both 512 and 1024 bits set.
Sorry again for the confusion. I think I will just go back to a tube, even tho it's a bit more verbose than a prism, but at least the optics are like I want them 🙂
14 REPLIES 14
Miha Nahtigal
I don't think you can do this. But you can change your layer's intersection priority to 0.
BIMquants.comBETA - Quantities and Costs Estimation with Archicad AddOn :: rushing to publish a beta preview
runxel
Legend
D%mn. That would be quite silly. Why then even have the line elimination flags, if they are useless?
Hopefully Péter will drop by and sharing some knowledge.
In the end I could just go very ugly and make them tubes a fraction of a mm smaller.
Perhaps I am missing something, but I think this line eliminating thing is related to the coplanar adjacent surfaces hard coded within AC.
Either you change the layer priority number or create a different surface to show the line.
I have mentioned this on a Line/Surface Merging Control wish.
GS did give some prompt feedback at the time (Thanks Gergely Hari!). It seems they are more for including this in the BM definition. Lets hope this for AC25.
Joachim Suehlo
If you use BODY - 1 at the end of a PRISM_ command, you can merge the surfaces of 2 PRISM_, which surfaces are not merged by default. Maybe there is something that works in the opposite direction.
Jochen Suehlo . AC12-27 . MAC OSX 14.4 . WIN11
David Maudlin
Or use the Poly2 command to draw the lines. I have done this in similar circumstances.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
runxel
Legend
Hey David, you mean with POLY_ set to `model wire`?
Mhm, that could be workaround.
Still a very dumb way, tho...
runxel
Legend
Sorry!
David Maudlin
Yes, my mistake, I mixed up the 2D and 3D commands. Lin_ is also an option.
David
A_ Smith
well, idk maybe i'm missing something
pen 20 !  red contour
material 99 ! grey material
prism_ 5, 1,
0,0,15,
1,0,15,
1,1,15,
0,1,15,
0,0,15
addz 1
prism_ 5, 1,
0,0,15,
1,0,15,
1,1,15,
0,1,15,
0,0,15
del top
AC 22, 24 | Win 10
