GDL
Prevent (!) Line elimination
runxel
Legend
Hey folks, I have a TUBE{2} and need my lines to be NOT eliminated.
See this picture below, just two cubes (as dummy) to show the issue. If you stack them, they will join and I somehow need to prevent this from happening, since they need to be visually different.
The MASK parameter for the tube{2} is set to 1+2+16+32, which means, the line elimination flags are not set (especially looking at you, 1024!).
Yet, it still eliminates the line between the two objects.
14 REPLIES 14
runxel
Legend
A. wrote:
well, idk maybe i'm missing something
In my example above it is the same object, just placed twice, so it is stacked upon each other, which will lead to the line elimination.
Joachim Suehlo
What is different in your script to the one from A. Smith, that you do not get the lines?
Jochen Suehlo . AC12-27 . MAC OSX 14.4 . WIN11
Guru
Two boxes in TWO objects vs two boxes in ONE object.
Joachim Suehlo
This is interesting, because 2 double boxes on top of each other have a separation line,
while 2 singles boxes don't have.
Peter Baksa
Hi all,
cprism_{3} can control line elimination:
cprism_{3} 0, 0, 0, 0,
	4, 1,
	0, 0, 0, 15, 0,
	0, 1, 0, 15, 0,
	1, 1, 0, 15, 0,
	1, 0, 0, 15, 0
Péter Baksa
Software Engineer, Library as a Platform
Graphisoft SE, Budapest
