Archicad C++ API
Property Expression language
bimdo
what kind of language is used in the property expressions? It's near by excel, but it's in many point not excel.
Thank you;)
Peter Baksa
It's just an expression with common-sense operator precedence. There are no loops or variables which would make it a language technically.
Here is some help: https://community.Graphisoft.com/t5/Document-articles/Expression-based-properties-FAQ/ta-p/303797
Péter Baksa
Software Engineer, Library as a Platform
Graphisoft SE, Budapest
Podolsky
Ace
It has actually LISP syntax. I don't think this is specific language been used. Probably created especially for that function. Strange that there GDL was not been used.
Peter Baksa
Péter Baksa
