Archicad Python API
About automating tasks in Archicad using the Python API.
Python - Handling Zone information
pedrocollares
I've been starting to dive into the Python integration in order to put up a few routines regarding zone information in our firm. I'm a little bit familiar with the programming language itself, but I'm clueless on how to get the info from the elements.
I'm starting out with this, to get a list of all Zones in the project. Then there's a few things I need to be able to access in each of those zones. Which are:
  • Zone name
  • Layer to which they belong
  • Calculated area
  • Zone category
  • Home Story index
  • Home Story name
I'm not even sure if such information is available through the Python integration, though, in case they are, it would be good if I could, inside that 'element' loop assign them to variables so I can handle them across the code.
I hope there's a way to do such. Thanks in advance! 🙂
Architect / BIM Manager at IDEIA1 - www.ideia1.com.br
Archicad 26 / Windows 10 64
Hi Pedro,
There was a discussion about this a few months ago which I think is relevant for what you want to do: https://community.graphisoft.com/t5/Developer-forum/Home-Story-Name-in-Python/m-p/31298
It boils down to 2 solutions:
The first option is easier to realize but needs extra steps in each project. The second option needs additional expertise with C++ Add-Ons.
Best, Bernd
Bernd Schwarzenbacher - Archicad Add-On Developer - Get Add-Ons & Archicad Tips on my Website: Archi-XT.com
pedrocollares
Updates on my own thread 😅
Apparently all those worked:
They were put out correctly at the listener:
Although, as it seems, there is no Built-in property available to get the Home Story Index. I think I'll handle that by doing a comparison between the elevation to Project Zero and the Project's Story elevation
Anyone has directions on how to obtain those Home Story info?
Hi Pedro,
Best, Bernd
pedrocollares
Indeed, I'm for now going through this direction. Since the routines I mentioned are meant to be used only inside our firm, I think having the need to configure custom properties won't be an issue.
Thanks for the response 🙂
