Archicad Python API
About automating tasks in Archicad using the Python API.
Python - Hidden / Visible elements information
davidrubio
Would there be a way to know if an element is visible or hidden when running a python script?
I'm working on a script that I would like to consider only visible elements (because I can't get their renovation status...)
Thanks in advance,
David
5 REPLIES 5
poco2013
Mentor
You can get the renovation status with:
value = acu.GetBuiltInPropertyId('Category_RenovationStatus')
The Python API does not have available, the visibility of elements but you can get the Layer Name of a element with 'ModelView_LayerName'
Then get the visibility of that Layer with: 'ModelView_IsLayerVisible'
Gerry
davidrubio
Thank you very much Gerry,
This is exactly what I need!
How do you find these values? It would prevent me from disturbing you! 😉
I have a "GetAllPropertyNames" list but I didn't see anything 😞
David
poco2013
Mentor
TRY:
result = acc.GetAllPropertyNames()
for x in result:
        print(x)
You will get a listing of all property names in the console.
The builtin properties are the 'nonlocalizedname' ones
Gerry
davidrubio
Thanks for your return
That's what I did but I don't have the properties you are talking about... I only have 'ModelView_LayerName'
Maybe it's because I had Archicad 24? These properties may only be available on 26...
I will try (I have all versions since 5...)
What does mean 'nonlocalizedname'?
Thanks a lot for your help,
David
The latest version of the Python API is 26.3000 available via pip install.
Graphisoft divides properties into two categories -- 'builtin' and 'custom'.  Custom properties are user created and are specific to a certain category of elements or 'localized'. Builtin properties may be read only or read/write and are generally applicable to all elements or exist for a specific purpose. They are universal or 'nonlocalized'
Gerry
