Developer forum
Python Upgrade
poco2013
Graphisoft just release a new version of the Python APi -- version 24.3022. The upgrade fixes a compatibility problem with Python 3.9. However, the documentation was not upgraded. Am I correct in assuming that no new commands were added? There is no documentation after version 24.3004
Also, I should have noticed this earlier, but it appears that the command line was removed from the Python palette from the experimental version.
This makes it difficult to peruse the python environment and perhaps determine the commands and help info there?
Can we get the command line back?
Gerry
Windows 10 - Visual Studio 2019; ArchiCAD 25
3 REPLIES 3
runxel
Mentor
Baffled me big as well.
Especially since the big words were "we will deliver a big upgrade in the api with the first update of AC 24"... – well here it is but again nothing else than broken promises.
AC 24 [ger] | Win 10 | Developer of the GDL plugin for Sublime Text |
«Furthermore, I consider that Carth... yearly releases must be destroyed»
Have you guys seen this:
https://archicad-talk.graphisoft.com/viewtopic.php?f=10&t=71183
This means the final version of the Update is coming soon, so we will soon see if it includes any updates to Python.
Laszlo Nagy, Lead Moderator, Community Admin
AMD Ryzen 1700X CPU, 48 GB RAM, NVidia GTX 1060 6GB, 500 GB NVMe SSD
2x28" (2560x1440), WIN10 PRO ENG, AC20-AC25
Loving Archicad since 1995
runxel
Mentor
Yes, I've seen it, but I can't remember a single time were the preview was significantly different from the final one.
Also I remember the last times well! Polygonal openings or ramps anyone?
So I don't have too much faith left, sadly.
