2020-08-22
08:17 AM
2021-09-15
12:52 AM
Noemi Balogh
2020-08-26 12:53 PM
# Simplest example for creating a Layout in Archicad # BOML | runxel 2020 # v1.0 | works in ac24.b3008 # create_layout.py # for <https://archicad-talk.graphisoft.com/viewtopic.php?f=23&t=70570#p315412> from archicad import ACConnection conn = ACConnection.connect() assert conn acc = conn.commands act = conn.types acu = conn.utilities #### some basic config #### master_name = "A2 Querformat" # the Master Layout you want to use parent_name = "Parent" # Parent folder name lname = "New Layout" # Name of the layout to be created # DIN A2 format size; always millimeter lhor = 594 lvert = 420 lmargin_left = lmargin_top = lmargin_right = lmargin_bottom = 0 # Declare the appropiate Layout Parameters (see API for more info) lparam = act.LayoutParameters(lhor, lvert, lmargin_left, lmargin_top, lmargin_right, lmargin_bottom, "", False, False, False, 1, 1, "", "", False, False) # which tree to checkout: 'LayoutBook', 'PublisherSets', 'ViewMap' root_tree_loc = 'LayoutBook' # Retrieve the Root Item layoutbook_tree = acc.GetNavigatorItemTree(act.NavigatorTreeId(root_tree_loc)) # Now a bit weird stuff: # For the FindInNavigatorItemTree function we need a criteria function, which gets called # with the item to check as only parameter. # We will then automatically loop over all items in the defined tree. # In this function we can decide if the current item adheres to our criteria, # if so, we will return true. def findMaster(item: act.NavigatorItem): return True if item.name == master_name else False def findParent(item: act.NavigatorItem): return True if item.name == parent_name else False list_master = acu.FindInNavigatorItemTree(layoutbook_tree.rootItem, findMaster) list_parent = acu.FindInNavigatorItemTree(layoutbook_tree.rootItem, findParent) lmaster = list_master[0].navigatorItemId lparent = list_parent[0].navigatorItemId # Now actually create the Layout; returns a GUID on `new_layout` new_layout = acc.CreateLayout(lname, lparam, lmaster, lparent)
