GDL
RGB fills
Pertti Paasky
Hi!
I can create RGB fills by exploding a pdf file which includes colored fills. Sorting them by color seems to be impossible, or am I wrong?
Anyway it would be nice to create RGB fills in 2d script in same way as You can define material in 3d script.
That is important if You want to create objects that do not change colors depending on the pen set.
- AC-24 FIN - WIN 10 - HP Zbook -
“A winner is just a loser who tried one more time.”
George M. Moore, Jr.
runxel
Legend
You can't get RGB fills of a certain color.... (i.e. with Search&Find). It's really a sad mess when you're trying to clean up things.
You can however achieve 2d RBG fills in GDL with a little trick. I've just made an object that can do any RBG color you'd like. Even RAL and NCS are possible.
Lucas Becker | AC 27 on Mac | Author of Runxel's Archicad Wiki | Editor at SelfGDL | Developer of the GDL plugin for Sublime Text |
«Furthermore, I consider that Carth... yearly releases must be destroyed»
Pertti Paasky
runxel , thanks anyway. -Yes, I know one tric how to make 2d rgb fills, too. Do You want to share Your Idea?
