GDL
Removing an array key (with value)
dushyant
Hi
As a dictionary key can be removed using the function REMOVEKEY (dictionary.key), is there a way to remove an array's key (with value)?
I tried:
myDict.myArray[1] = 1
REMOVEKEY(myDict.myArray[1])
but that does not seem to remove it.
Thanks
runxel
Legend
Sadly, there is no native way to delete/pop items from an array. This makes it necessary to do a bit of juggling.
dim arr[]
  arr[1] = 0.1
  arr[2] = 0.2
  arr[3] = 0.3
! index of the item you want to delete
todelete = 2
dim new_arr[]
check = 0
for i = 1 to vardim1(arr)-1
	if i = todelete then check = 1
	new_arr = arr[i+check]
next i
arr = new_arr
print arr   !>>> will print:  "0.1  0.3"
dushyant
Hi runxel
Ok, I get the idea. Thanks a lot!
