Developer forum
Resource ID range for GDLG and GICN
Oleg
From API documentation:
The resource ID of the palette should be between 32400 and 32499
Resource IDs for modal dialogs can be between 32500 and 32767
Does this limitation valid ?
Is there any limitation for TabPage dialog resource ID ?
( 32500-32767 range so small )
Is there any limitation for GICN resource ID ?
Akos Somorjai
Hi Oleg,
No, the only limitation is that any resource IDs should be in the 1 – 32767 range; that applies to GICN IDs as well.
Best, Akos
Akos Somorjai
Hi Oleg,
Best, Akos
Oleg
Hi Akos
Thank you for the answer.
Good news.
