Archicad C++ API
Roll Down Palette
I want to create a Roll Down Palette like Toolbox. I found the BasicElementIconsRollDownDialog example in DG_test the same as what I wanted but I don't know how to convert it to Palette.
Could you please help me?
Sorry for my English.
Tibor Lorantfy
Graphisoft Alumni
Graphisoft Alumni
BasicElementIconsRollDownDialog inherits from UD::RollDownModalDialog.
If you want a Palette, then you have the change the base class to UD::RollDownPalette. That's the main difference 😉
1 REPLY 1
Tibor Lorantfy
Graphisoft Alumni
Graphisoft Alumni
