Archicad C++ API
[SOLVED] Is there a way to make a loading progress bar
Hi
I would like to know is there a way to make a loading progress bar by AC API.
I'm getting information from web service and somethimes it's take 10 second or more so I want to show loading process.
If there is not a solution by AC API then is it right to do it by third party library, for example by BOOST ?
Please give me an advice.
Tibor Lorantfy
Graphisoft Alumni
Graphisoft Alumni
yes, AC API provides two options to make progressbar:
1) You can use DG::ProgressBar class (defined in DGBarControl.hpp).
- first define the progressbar in your GRC resource file:
'GDLG'  32500  Modal | noGrow      0    0  312  195  "Dialog with ProgressBar" {
/* [  6] */ ProgressBar			   13  140  286   15	/*minValue:*/ 0  /*maxValue:*/ 100  ClientEdge
- add DG::ProgressBar to your dialog class:
class MyDialog : public DG::ModalDialog
private:
		// friend classes
	friend class	MyObserver;
private:
	DG::ProgressBar		m_progressBar;
public:
	MyDialog (GSResModule dialResModule, short resId, GSResModule dialIconResModule);
   ~MyDialog ();
- in the constructor of your dialog don't forget to initialize the progressbar:
MyDialog::MyDialog (GSResModule dialResModule, short resId, GSResModule dialIconResModule):
	DG::ModalDialog		(dialResModule, resId, dialIconResModule),
	m_progressBar	(GetReference (), 6),
- now you can use the initialized progressbar in you code the following way:
m_progressBar.SetValue (<new value between minValue and maxValue>);
2) You can use the ACAPI_Interface ProcessWindow methodgroup to show a processwindow with a progressbar.
// Init processwindow:
	short nPhase	= 1;
	Int32 maxValue	= 100;
	ACAPI_Interface (APIIo_InitProcessWindowID, "<progressTitle>", &nPhase); // you can define more phases also
// Start progressbar:
	ACAPI_Interface (APIIo_SetNextProcessPhaseID, "<progressSubtitle>", &maxValue);
// Update progressbar with new value:
	Int32 progress = 0;
	ACAPI_Interface (APIIo_SetProcessValueID, &progress, NULL);
	progress++;
// Processwindow contains a Cancel button also:
	if (ACAPI_Interface (APIIo_IsProcessCanceledID, NULL, NULL)) {
		// user cancelled the process!
- This is much more easier.
Regards,
Tibor
Thank you for the help. I use second one!
