Archicad C++ API
[SOLVED] New line in dimension note
ReignBough
I found out that the note in dimension can now be a multi-line. But when I tried using "\n" it was shown as the replacement character "▯" but it is correctly displayed in the settings dialog. When I tried using paragraph marker, "¶", it is shown as it is.
EDIT: (2016 Feb 02)
What I did was:
for new line:
sprintf((*memo.dimElems).note.content, "<MeasuredValue>\n%d EQ PANELS", panelCnt);
for paragraph marker:
sprintf((*memo.dimElems).note.content, "<MeasuredValue>¶%d EQ PANELS", panelCnt);
~ReignBough~
ARCHICAD 26 INT (from AC18)
Windows 11 Pro, AMD Ryzen 7, 3.20GHz, 32.0GB RAM, 64-bit OS
6 REPLIES 6
I don't think that either one is correct.
You should not see any such character.
The text following such a character should simply be placed into a new line.
This might have something to do with your Archicad version and Windows version not working together well.
Try upgrading to the latest hotfix and see if this problem persists.
ReignBough
Can anyone move this post on Developer forum, please? I post it on a wrong forum. Thanks.
~ReignBough~
I have moved it to the Developer Forum.
Ralph Wessel
Mentor
How about creating a multi-line dimension manually (i.e. with ARCHICAD's tools) and then examining the resulting data through the API to see what delimiter it uses?
Ralph Wessel BArch
ReignBough
Thanks. Found it. It is ASCII 13, or 0x0D, or '\r'.
~ReignBough~
Katalin Borszeki
Hi All,
as Laszlo Nagy pointed out before me, please download the latest update!
best, k
Katalin Borszeki
Implementation Specialist
GRAPHISOFT
