Developer forum
Single Handle (one side) in a Curtain Wall Door Panel
goncalovalente
Hello!
The curtain panels are really versatile and I use them to make continuous cabinet doors, but I have a problem: I want to insert a handle on each CW door just in one side only.
Will it be easy to configure in GDL (CW Door 25.gsm), or should I put it in the Wishes?
Thanks,
It would be possible to achieve by modifying that "Porta PC 25" Library Part that is generating the Curtain Wall Panel. However, you would have to introduce new variables, and you would have to modify several scripts, possibly even the interface within the Library Part, all of which requires more advanced GDL skills, based on which I would say you should make a Wish for this feature.
Get Archicad Tips at https://twitter.com/laszlonagy
AMD Ryzen 1700X CPU, 48 GB RAM, Nvidia GTX 1060 6GB, 500 GB NVMe SSD
2x28" (2560x1440), WIN10 PRO ENG, AC20-AC26
Loving Archicad since 1995
Thank you Laszlo.
I´ve manage to take it of inside Sash file, but still I'll create a Wish feature.
