2016-02-11 02:20 PM - last edited on 2023-07-12 09:12 PM by Doreena Deng
2016-02-18 11:15 PM
stefan wrote:Yes, I believe they're fully compatible (with the limitations you noted).
Does the Devkit also support ArchiCAD Start Edition?
E.g. can an ArchiCAD 19 APX run on ArchiCAD Start Edition 2016 (based on 19)?
I assume that you have to take care not to use methods that call into non-supported functionality (e.g. Publisher, ...).
2016-03-10 09:14 PM
2016-03-18 06:55 PM
stefan wrote:There isn't any restriction on the API, but restrictions inside ARCHICAD do apply; and yes, please do not call any unsupported function (though you should get an error code if you do that...)
