Developer forum
TEXTBLOCK lines height adjustment
pedrocollares
I've been putting up a custom schedule in GDL to list finishes of a project out of surfaces, and it seems to be working all fine, but I would like to have the text block lines a bit closer to each other.
Is there a height factor to be applied to text blocks? I couldn't find such thing in the reference guide.
Thanks in advance!
Architect / BIM Manager at Ideia1 - www.ideia1.com.br
Archicad 25 / Windows 10 64
4 REPLIES 4
DGSketcher
Champion
See if these links help...
Creating a Label Text with AC Globals
Parameters for Text Handling
Line spacing is controllable in the Paragraph command
Apple iMac macOS Ventura / AC26UKI (most recent builds)
It is not in the textblock but paragraph definition and it is called line_spacing there:
http://gdl.graphisoft.com/reference-guide/inline-attribute-definition#TEXTBLOCK_gdlcommand
pedrocollares
Oh right. Then I assume I should use paragraph instead of textblock to be able to control that. I can't see how I define the paragraph's width, though. I'm using textblock because I need to restrict the width of the text to have an automatic line break.
You _are_ using paragraphs when using textblocks  😉
