GDL
Text in objects
Yvonne
I have created a 2D object with an editable text box. How can I edit the object so the text will be readable when it gets rotated?
AC26 | Win11 | 64 bit | 32Gb RAM | Intel i9-9900K @ 3.60GHz
5 REPLIES 5
Lingwisyer
Guru
You could pull SYMB_ROTANGLE and use that to counter the object rotation or use n = REQUEST ("view_rotangle", "", angleViewRotation) to counter the View rotation.
If it is a Label you can use AC_bLabelAlwaysReadable.
Have a browse through the GDL Reference Guide, it is all there.
Ling.
DGSketcher
Legend
This may help...
http://gdl.graphisoft.com/tips-and-tricks/how-to-make-an-always-readable-text-cs
Yvonne
Ling.
Thanks Ling.
I'm new to this so still trying to wrap my head around GDLs.
Been trying to read up on it but still no idea where to enter the “View_Rotangle” request
Lingwisyer
Guru
The article that DGSketcher linked shows you how to set it out. Just replace the TEXT2 with what ever text and shapes you are wanting to rotate.
Ling.
You only need to worry about “View_Rotangle” if you want to counter-act the rotation of the screen in Archicad.
If not, don't worry about it.
If you just want to counter-act the rotation of the object, then use -SYMB_ROTANGLE in your TEXTBLOCK command - for the 'angle' value in the TEXTBLOCK command.
