GDL
UI_TEXTSTYLE_INFIELD and arrays
Bruce
Is there a way to use UI_TEXTSTYLE_INFIELD with arrays? I can only seem to get it to work with parameters that are not arrays.
Bruce Walker
www.brucepwalker.com
Barking Dog BIM YouTube
Mindmeister Mindmap
-- since v8.1 --
AC27 5003 INT Full | Windows 11 64 Pro | 12th Gen Intel i7-12700H 2.30 GHz | 64 Gb RAM | NVIDIA GeForce RTX 3060 32 Gb
Bruce
It was easier than I thought: I just needed to use the UI_TEXTSTYLE_INFIELD{2} command. The GDL reference guide is a little misleading in that it has the inverted commas on the wrong commands.
Bruce Walker
Mindmeister Mindmap
-- since v8.1 --
Guru
Just a standard Infield array but it might be related: https://archicad-talk.graphisoft.com/viewtopic.php?p=298612#p298612
Bruce
Bruce Walker
Mindmeister Mindmap
-- since v8.1 --
