2021-08-23
07:05 AM
2021-09-13
11:49 PM
Noemi Balogh
2021-08-23 08:33 AM
2021-08-23 06:25 PM
2021-08-23 06:37 PM
Lingwisyer wrote:
Since they are just headers, you could swap to using theTitleparameter type instead of using the parameter group(?) function. That is if you want to remove the collapsible function all together.
2021-09-02 01:15 AM
They probably can stay unfolded as a default if You use the ui script and ui_listfield command
instead of the plain vanilla parameters view...yet the hideparameter all, (_list of ones not to hide_)
has to be in use not to show the parameters themselves
