Archicad C++ API
Using AddOn in 3D
Dayiz
Hello everyone!
I'm currently trying to write an AddOn which selects all tilted Walls in a project.
I managed to get the functionality running, but i'm only able to use the AddOn in 2D view, but as soon as i go in 3D, (e.g.: 3D Generic Perspective), the AddOn is greyed out.
Is this the general behavior or is there something I'm missing? Our architects need it in 3D view.
Thanks for any help!
Kind Regards
Dayiz
Hi Dayiz,
Are you talking about the menu item becoming gray?
Then I think you are looking for the menu control codes. For 3D views you can use "^E3" like in this example:
'STR#' 32500 "Menu string" {
/* [  1] */     "This would be enabled also in 3D views^E3"
You can find more details about it on this documentation page: https://archicadapi.Graphisoft.com/documentation/required-resources
Or in case you are creating a palette, you will need something like this
    GSErrCode err = ACAPI_RegisterModelessWindow (paletteRefId, PaletteAPIControlCallBack,
                                                  API_PalEnabled_FloorPlan + API_PalEnabled_3D
+ API_PalEnabled_DocumentFrom3D,
GSGuid2APIGuid (paletteGuid));
 (Details here: https://archicadapi.Graphisoft.com/documentation/acapi_registermodelesswindow)
Best,
Bernd
Bernd Schwarzenbacher - Archicad Add-On Developer - Get Add-Ons & Archicad Tips on my Website: Archi-XT.com
4 REPLIES 4
DGSketcher
Legend
You do know you can use Find & Select for this?
Hi Dayiz,
Best,
Bernd
Thank you very much, this is what I was looking for 🙂
Honestly no, I didnt. But I'm not an architect, just a developer 😄
But I think that tool wouldn't suffice. We also want to check for all multiples of 90° or 45° and also have the option to enter a project offset. While you could manually put in all those values, it would be easier to solve this problem with an addon.
But thanks for your input 🙂
