Developer forum
Using Param-O to parameterise old dumb objects
Paul King
Is there a way to drag or import an existing GDL object (or a selected group of elements from an ArchiCAD window) for parametrization in Param-O?
Otherwise Param-O looks like a pretty excruciating way to assemble an object with complex geometry if it needs to be built from scratch using primitives in the Param-O editing environment, compared with what you can do so much faster in a standard ArchiCAD editing environment, before dragging and dropping or saving selected items as GDL?
Struggling to see the point, or how this makes things easier for noobs like me if this is the case?
PAUL KING
https://www.prime.net.nz
ArchiCAD 8-25
Octane Render Plugin for ArchiCAD
Twinmotion 2021
Windoze 10
Intel Core i9 10900K
Nvidia Gforce RTX 3080
32 Gb DDR3
2x4K monitor extended desktop
4 REPLIES 4
Braza
I am not a PARAM-O expert, but I think it can. Just drag a GDL Object element and define it inside its dialog box.
Hope this helps.
Paulo Henrique Santos, Architect
AC24_INT#3008 / I7 / 16Gb / 512Mb SSD / Windows 10
Paul King
I had a go at this, but with the Param-O dialog open, I was unable to switch focus to any other ArchiCAD window in order to select anything to drag
I also couldn't spot any obvious import function.
Very likely missing something - have only just started playing with it.
PAUL KING
ArchiCAD 8-25
Twinmotion 2021
Windoze 10
32 Gb DDR3
Braza
My bad... I meant drag 'n drop inside PARAM-O.
Like this:
Paul King
Thanks - I will have a play with that
PAUL KING
ArchiCAD 8-25
Twinmotion 2021
Windoze 10
32 Gb DDR3
