GDL
View ID/Name in a gdl-object
Mats_Knutsson
I want to create a simplified "stamp" to put on every view that is being exported as dwg.
I'd like this object to read Building name and Date which I've done but I can't figure out how to get the ID and Name of the view from the View Map? Any idea?
Best,
Mats
AC 25 SWE Full
6 REPLIES 6
Dominic Wyss
Hey Mats
Have a look at http://gdl.graphisoft.com/reference-guide/drawing-title-attributes
Edit: Make sure you've selected "By View ID" and "By View Name" in your drawing settings.
AC27 CHE - macOS Ventura M1
kuvbur
You can use a custom linked marker and link to the view. To display the name, use AC_MarkerText_2. In attach - example of custom detail marker
Structural engineer, developer of free addon for sync GDL param and properties
Mats_Knutsson
It's a View as a saved View in the View Map...not a Layout or on a layout.
AC 25 SWE Full
kuvbur
try detail marker at #323921, that work. It's only way to get view name.
Mats_Knutsson
thx. will test if it's a viable solution.
AC 25 SWE Full
sinceV6
Hi.
You need to look into the "HomeDB_info" Request.
Best regards
