GDL
Warnings by "Check script" when populating an array in a loop with an INPUT() test as the condition
MetalFingerz
I have an issue with an array in a loop iterating a text file. I'm in the Interface script and here is the code :
DIM array[]
n = 0
i = 1
line = 2
row = 2
value = ""
channel = OPEN("TEXT", "text.txt", "SEPARATOR='\t', MODE = RO, LIBRARY")
REPEAT
	n = INPUT(channel, line, row, value)
	array[i] = i
	line = line + 1
	i = i + 1
UNTIL n < 1
CLOSE channel
! Values are 1, 2, 3 and 4
So my array gets populated properly (with numbers in the example but the idea is to populate it with values from the text file), I can reference the array members individually and so on. But every time I check the script, it gives me warnings telling me the indexes are outside the range. This happens with DO WHILE and REPEAT UNTIL loops (didnt try WHILE DO but it's probably the same) but not if I manually input
	array[i] = i
	line = line + 1
	i = i + 1
x number of times that I need. For example if my text file is 10 lines long and I copy paste that code 9 times, no error is being thrown when I check the script. However that's not an acceptable solution as I need to iterate through the array with a loop.
I think I zero'd the issue at the UNTIL condition. If I put
UNTIL i > 4
there's no error being throw but not if I keep the INPUT() test
UNTIL n < 1
When I use the object and its interface in a project, there's no errors that pops up in the Report window, it's only when I get to check my script in the Interface script that something is shown.
Any idea what I'm doing wrong with my loops ? I'm using AC 24 6004.
MetalFingerz
Well I fixed the issue by initializing all members of the array first.
Don't know why that worked though.
MetalFingerz
Did you paste the exact code that gave the warning? Because "line" is a reserved keyword with error message "Keywords can't be used as variables at line 4". If I change that, there are no warnings.
Péter Baksa
Software Engineer, Library as a Platform
Graphisoft SE, Budapest
