Developer forum
GDL coding questions, Python and add-on development using the API Dev Kit.
What error is -2130312307?
LeeJaeYoung
Mentor
I added a menu in element_test and an error occurred, so I modified the existing menu, but the same error occurs.
This is the ac26 version.
GSErrCode __ACENV_CALL ElementsHotlink (const API_MenuParams *menuParams)
GSErrCode err = NoError;
switch (menuParams->menuItemRef.itemIndex) {
case 1: Do_CreateBeam(); break;
//case 1: err = Do_CreateHotlink (); break;
case 2: err = Do_ChangeHotlink (); break;
case 3: err = Do_UpdateHotlink (); break;
case 4: err = Do_DeleteHotlink (); break;
case 5: err = Do_BreakHotlink (); break;
case 6: Do_ListHotlinks (); break;
case 7: Do_ListHotlinkProxyElements (); break;
case 8: Do_ModifiyHotlinkNode (); break;
default: break;
return err;
} /* ElementsHotlink */
AC25 5010 / AC26 4019 on window 11
4 REPLIES 4
Miha Nahtigal
Are you calling your create element function inside ACAPI_CallUndoableCommand block?
Archicad Error Codes
APIERR_NEEDSUNDOSCOPE -2130312307 8106038D The called command should be encapsulated in a ACAPI_CallUndoableCommand scope.
Gerry
Windows 10 - Visual Studio 2019; ArchiCAD 26
I found out about my problem and fixed it.
Thank you very much.
And
If you know how ac26 develops api with visual studio 2019, can you explain in detail?
I can't make it with cmake
I am studying while adding in element_test.
I also got a template file, but this is a question because I don't know where and how to install it and how to run it.
Re: How to start api (c++) in 26? - Graphisoft Community
akiss
Hi
The best way to start developing Archicad AddOns is to follow the steps in Getting started with Archicad Add-Ons.
Best regards,
András
