When I open a 24 light object I see that the macro seems to get called a few times - parameter script, 3D script and Interface script.
I have a hard time following Graphisoft objects though!
It looks like that macro does more than just the simple settings in your object.
I think I would just 'Save As' your original object and edit that.
It will have the new parameters and I assume you just ignore them.
I have no idea how the old controls show up in the parameter list.
Delete C,D E F & G and that interface part in the parameter list disappears - but you can not re-create it, as you can't create the old parameters with the old types again.
And it doesn't work with the new 'gs_...'parameters.
So 'Save As' an old light seems to be the only way to keep them.
You can't delete the new parameters because they are part of the light sub-type, but you can hide them - although I am not sure if that is necessary.
The object (the interface part in the parameter list) still seems to be using the old parameters.
